Abundance, How do I generate a sphere
How can I generate a sphere with Abundance?
There is a loft function that connects a tube through a series of curves, you might be able to get close with that. define a d rotate that and then loft through those.
Bar coded a sphere that you can use too
https://abundance.maslowcnc.com/run/BarbourSmith/Sphere
You import this as a molecule into your project. From inside a project you go to the import export palette and then to the Git hub molecule tool and then search for sphere.
If you know more coding there is a code node that you can use to make other things happen than are in the tools.
Here is a sphere created in abundance by lofting
https://abundance.maslowcnc.com/run/wouldchuckit/Sphere_by_lofting
To place either of those in your project right click anywhere at the top half of the screen and then choose “GitHub molecule” from the right click menu and then search for sphere
