Abundance - Loft - Query
Query - is there a limit on size of a ‘Loft’. I am attempting to create a cone shape, bottom circumference 40mm, top 35mm with a height of 60mm and it does not let me do this.
Also, in the loft molecule one of the options is Add Extrude, which it then flags as illegal.
There should not be a limit to how high you can loft.
Does it work with lower heights but then stop working at some point?
Thanks for catching that, I’ll get that removed asap!
Demonstration of problem.
Initially set height to 60, circleDia1 to 40 and circleDia2 to 35. It gave me what you would expect, cylinder and loft same height. I then reset the height to 40, cylinder followed, Loft did not. Creating a new loft in the same workspace is always the same height as was set initially with the first loft.
Link to Test_Loft Abundance - BETA
Thanks for fixing this Bar
We need a subcategory for Abundance under Software
Thanks for reporting it! I’m sorry that I forgot to respond that it was fixed :grin:
