Bug? Pink dot position didn't update after clicking home
Bug: I had the maslow over on the far left edge… clicked the “home” button… maslow returned to center of work area ( where I had home set ) .. but I see that the pink dot still shows maslow on the far left edge. Pink dot should be in the middle of the reticle. I tried to click and cylce through the different views; no dice.
What to do now? Attempt a cut with things in this buggy situation? Or try to power cycle and home it doesn’t make me REAP?
Maslow-serial (9).log (60.1 KB)
From your log file it looks like the Maslow still thinks it on the left
[MSG:INFO: TL belt: 1994.211 TR belt: 3695.371]
[MSG:INFO: BL belt: 1987.716 BR belt: 3675.597]
[MSG:INFO: After update - mpos: X=-1069.571 Y=-11.052 Z=0.000]
[MSG:INFO: Requesting state change from Taking Slack to Ready To Cut]
I think I would do a REAP to get everything sane again (I know it’s a pain), but it’s better than falling off the edge
After a few minutes I checked again and the dot was in the right spot.
Up until this version, the crosshairs did not follow the XY location at all, but stayed centred. This is new (and welcome).
I’m fine with the reticle being in center of workspace and using the pink dot for maz position. I think having the reticle follow the pink dot would be unnecessary.
It doesn’t follow the dot, it moves the reticule to where you set the home position e.g. This shows the original home
Then I moved XY home to where i want the cut and loaded a file, makes it easy to see where cut is in relation to Home location.
Available in next release
