First of all let me say that I’m impressed with the new calibration algorithm. It runs so much faster than the old one. Until yesterday I had a horizontal wooden frame, and the calibration was quite accurate.
Today I switched to anchor bolts in my garage floor, spaced at appr. 4500 x 3300 mm. I ran the calculation multiple times, but it fails to find the anchor points within an accuracy of 5 mm.
See also the log:
Serial Messages
Index.html Version: v1.24.0
[MSG:INFO: Zm=2.000mm, Z home=0.000mm, Z position=2.000mm]
Find Anchors
[MSG:INFO: Requesting state change from Belts Extended to Finding Anchor]
[G92:0.000,0.000,0.000,0.000,0.000]
[G54:-306.265,-160.856,0.000,0.000,0.000]
[MSG:INFO: Machine Position found as X: 21.877 Y: -287.434]
[MSG:INFO: Setting motor positions from hardware readings:]
[MSG:INFO: TL: 2645.942 TR: 2651.471 BL: 2629.806 BR: 2629.162]
[MSG:INFO: Succeeded]
[MSG:INFO: Zm=0.000mm, Z home=0.000mm, Z position=0.000mm]
[MSG:INFO: Detected HORIZONTAL orientation (extension <= 35.000 mm)]
[MSG:INFO: Orientation set to: HORIZONTAL (Maslow_vertical=false)]
[MSG:INFO: Waypoint 0 coordinates: X=0.000 Y=ovf]
[MSG:INFO: Center point off by: TL: -0.000 TR: 0.000 BL: 179.469 BR: 261.869]
[MSG:ERR: Center point off by over 100.000mm]
[MSG:INFO: Frame size successfully adjusted to: 3947.716 x 3947.716]
[MSG:INFO: Machine Position computed as X: -4.579 Y: -13.275]
[MSG:INFO: Waypoint 1 coordinates: X=145.421 Y=-13.275]
[MSG:INFO: Waypoint 2 coordinates: X=145.421 Y=136.725]
[MSG:INFO: Waypoint 3 coordinates: X=-4.579 Y=136.725]
[MSG:INFO: Waypoint 4 coordinates: X=-154.579 Y=136.725]
[MSG:INFO: Waypoint 5 coordinates: X=-154.579 Y=-13.275]
[MSG:INFO: CLBM:[{bl:2782.89, br:2781.31, tr:2804.09, tl:2797.63},{bl:2891.67, br:2682.91, tr:2698.77, tl:2895.58},{bl:2993.59, br:2777.73, tr:2596.42, tl:2813.24},{bl:2897.15, br:2872.53, tr:2697.64, tl:2710.29},{bl:2799.69, br:2970.14, tr:2802.29, tl:2607.21},{bl:2695.76, br:2904.66, tr:2895.05, tl:2675.28}]]
[MSG:INFO: Find Anchors fit: rms=0.476mm max=0.799mm perAnchor=[0.349,0.586,0.574,0.331]mm converged=1]
[MSG:INFO: Find Anchors recompute complete: tl=(15.674,3502.173) tr=(4379.062,3471.593) brX=4356.770 SSR=5.428 points=6]
[MSG:INFO: Waypoint 6 coordinates: X=0.000 Y=0.000]
[MSG:INFO: Waypoint 7 coordinates: X=0.000 Y=-80.765]
[MSG:INFO: Waypoint 8 coordinates: X=-260.606 Y=-80.765]
[MSG:INFO: Measured waypoint 9]
[MSG:INFO: Waypoint 9 coordinates: X=-260.606 Y=0.000]
[MSG:INFO: Measured waypoint 10]
[MSG:INFO: Waypoint 10 coordinates: X=-260.606 Y=80.765]
[MSG:INFO: Measured waypoint 11]
[MSG:INFO: Waypoint 11 coordinates: X=0.000 Y=80.765]
[MSG:INFO: Measured waypoint 12]
[MSG:INFO: Waypoint 12 coordinates: X=260.606 Y=80.765]
[MSG:INFO: Measured waypoint 13]
[MSG:INFO: Waypoint 13 coordinates: X=260.606 Y=0.000]
[MSG:INFO: Measured waypoint 14]
[MSG:INFO: Waypoint 14 coordinates: X=260.606 Y=-80.765]
[MSG:INFO: CLBM:[{bl:2782.89, br:2781.31, tr:2804.09, tl:2797.63},{bl:2891.67, br:2682.91, tr:2698.77, tl:2895.58},{bl:2993.59, br:2777.73, tr:2596.42, tl:2813.24},{bl:2897.15, br:2872.53, tr:2697.64, tl:2710.29},{bl:2799.69, br:2970.14, tr:2802.29, tl:2607.21},{bl:2695.76, br:2904.66, tr:2895.05, tl:2675.28},{bl:2781.33, br:2808.2, tr:2812.71, tl:2771.7},{bl:2759.79, br:2757.85, tr:2829.43, tl:2823.44},{bl:2588.28, br:2893.76, tr:2999.82, tl:2697.05},{bl:2598.16, br:2937.82, tr:2997.59, tl:2651.1},{bl:2651.16, br:2981.2, tr:2951.41, tl:2602.22},{bl:2815.86, br:2864.02, tr:2779.41, tl:2716.43},{bl:2989.74, br:2700.94, tr:2604.19, tl:2885.7},{bl:3017.74, br:2653.04, tr:2574.25, tl:2937.79},{bl:2971.62, br:2605.3, tr:2624.03, tl:2978.68}]]
[MSG:INFO: Find Anchors fit: rms=0.897mm max=2.022mm perAnchor=[0.591,1.129,1.135,0.553]mm converged=1]
[MSG:INFO: Find Anchors recompute complete: tl=(18.528,3460.886) tr=(4417.050,3425.571) brX=4393.291 SSR=48.259 points=15]
[MSG:INFO: Measured waypoint 15]
[MSG:INFO: Waypoint 15 coordinates: X=260.606 Y=-161.530]
[MSG:INFO: Measured waypoint 16]
[MSG:INFO: Waypoint 16 coordinates: X=0.000 Y=-161.530]
[MSG:INFO: Measured waypoint 17]
[MSG:INFO: Waypoint 17 coordinates: X=-260.606 Y=-161.530]
[MSG:INFO: Measured waypoint 18]
[MSG:INFO: Waypoint 18 coordinates: X=-521.212 Y=-161.530]
[MSG:INFO: Measured waypoint 19]
[MSG:INFO: Waypoint 19 coordinates: X=-521.212 Y=-80.765]
[MSG:INFO: Measured waypoint 20]
[MSG:INFO: Waypoint 20 coordinates: X=-521.212 Y=0.000]
[MSG:INFO: Measured waypoint 21]
[MSG:INFO: Waypoint 21 coordinates: X=-521.212 Y=80.765]
[MSG:INFO: Measured waypoint 22]
[MSG:INFO: Waypoint 22 coordinates: X=-521.212 Y=161.530]
[MSG:INFO: Measured waypoint 23]
[MSG:INFO: Waypoint 23 coordinates: X=-260.606 Y=161.530]
[MSG:INFO: Measured waypoint 24]
[MSG:INFO: Waypoint 24 coordinates: X=0.000 Y=161.530]
[MSG:INFO: Measured waypoint 25]
[MSG:INFO: Waypoint 25 coordinates: X=260.606 Y=161.530]
[MSG:INFO: Measured waypoint 26]
[MSG:INFO: Waypoint 26 coordinates: X=521.212 Y=161.530]
[MSG:INFO: Measured waypoint 27]
[MSG:INFO: Waypoint 27 coordinates: X=521.212 Y=80.765]
[MSG:INFO: Measured waypoint 28]
[MSG:INFO: Waypoint 28 coordinates: X=521.212 Y=0.000]
[MSG:INFO: Measured waypoint 29]
[MSG:INFO: Waypoint 29 coordinates: X=521.212 Y=-80.765]
[MSG:INFO: Measured waypoint 30]
[MSG:INFO: Waypoint 30 coordinates: X=521.212 Y=-161.530]
[MSG:INFO: CLBM:[{bl:2782.89, br:2781.31, tr:2804.09, tl:2797.63},{bl:2891.67, br:2682.91, tr:2698.77, tl:2895.58},{bl:2993.59, br:2777.73, tr:2596.42, tl:2813.24},{bl:2897.15, br:2872.53, tr:2697.64, tl:2710.29},{bl:2799.69, br:2970.14, tr:2802.29, tl:2607.21},{bl:2695.76, br:2904.66, tr:2895.05, tl:2675.28},{bl:2781.33, br:2808.2, tr:2812.71, tl:2771.7},{bl:2759.79, br:2757.85, tr:2829.43, tl:2823.44},{bl:2588.28, br:2893.76, tr:2999.82, tl:2697.05},{bl:2598.16, br:2937.82, tr:2997.59, tl:2651.1},{bl:2651.16, br:2981.2, tr:2951.41, tl:2602.22},{bl:2815.86, br:2864.02, tr:2779.41, tl:2716.43},{bl:2989.74, br:2700.94, tr:2604.19, tl:2885.7},{bl:3017.74, br:2653.04, tr:2574.25, tl:2937.79},{bl:2971.62, br:2605.3, tr:2624.03, tl:2978.68},{bl:2933.32, br:2554.33, tr:2669.26, tl:3025.9},{bl:2769.48, br:2630.49, tr:2829.29, tl:2951.65},{bl:2594.82, br:2803.47, tr:2993, tl:2793.01},{bl:2428.14, br:2977.92, tr:3159.39, tl:2643.38},{bl:2379.24, br:3030.12, tr:3212.37, tl:2598.1},{bl:2393.56, br:3073.21, tr:3214.6, tl:2550.35},{bl:2448.05, br:3109.08, tr:3172.29, tl:2500.16},{bl:2491.23, br:3148.82, tr:3131.49, tl:2449.48},{bl:2658.96, br:3107.58, tr:2964.46, tl:2475.93},{bl:2816.99, br:2940.91, tr:2786.44, tl:2641.91},{bl:2984.05, br:2777.09, tr:2609.65, tl:2811.48},{bl:3159.71, br:2619.35, tr:2433.44, tl:2984.1},{bl:3210.6, br:2578.54, tr:2382.49, tl:3035.65},{bl:3241.57, br:2534.06, tr:2357.87, tl:3087.09},{bl:3197.38, br:2483.52, tr:2409.08, tl:3129.43},{bl:3156.55, br:2431.96, tr:2460.16, tl:3169.01}]]
[MSG:INFO: Find Anchors fit: rms=1.496mm max=4.978mm perAnchor=[1.415,1.608,1.547,1.404]mm converged=1]
[MSG:INFO: Find Anchors recompute complete: tl=(29.155,3394.968) tr=(4489.910,3330.413) brX=4454.445 SSR=277.539 points=31]
[MSG:INFO: Measured waypoint 31]
[MSG:INFO: Waypoint 31 coordinates: X=521.212 Y=-242.295]
[MSG:INFO: Measured waypoint 32]
[MSG:INFO: Waypoint 32 coordinates: X=260.606 Y=-242.295]
[MSG:INFO: Measured waypoint 33]
[MSG:INFO: Waypoint 33 coordinates: X=0.000 Y=-242.295]
[MSG:INFO: Measured waypoint 34]
[MSG:INFO: Waypoint 34 coordinates: X=-260.606 Y=-242.295]
[MSG:INFO: Measured waypoint 35]
[MSG:INFO: Waypoint 35 coordinates: X=-521.212 Y=-242.295]
[MSG:INFO: Measured waypoint 36]
[MSG:INFO: Waypoint 36 coordinates: X=-781.819 Y=-242.295]
[MSG:INFO: Measured waypoint 37]
[MSG:INFO: Waypoint 37 coordinates: X=-781.819 Y=-161.530]
[MSG:INFO: Measured waypoint 38]
[MSG:INFO: Waypoint 38 coordinates: X=-781.819 Y=-80.765]
[MSG:INFO: Measured waypoint 39]
[MSG:INFO: Waypoint 39 coordinates: X=-781.819 Y=0.000]
[MSG:INFO: Measured waypoint 40]
[MSG:INFO: Waypoint 40 coordinates: X=-781.819 Y=80.765]
[MSG:INFO: Measured waypoint 41]
[MSG:INFO: Waypoint 41 coordinates: X=-781.819 Y=161.530]
[MSG:INFO: Measured waypoint 42]
[MSG:INFO: Waypoint 42 coordinates: X=-781.819 Y=242.295]
[MSG:INFO: Measured waypoint 43]
[MSG:INFO: Waypoint 43 coordinates: X=-521.212 Y=242.295]
[MSG:INFO: Measured waypoint 44]
[MSG:INFO: Waypoint 44 coordinates: X=-260.606 Y=242.295]
[MSG:INFO: Measured waypoint 45]
[MSG:INFO: Waypoint 45 coordinates: X=0.000 Y=242.295]
[MSG:INFO: Measured waypoint 46]
[MSG:INFO: Waypoint 46 coordinates: X=260.606 Y=242.295]
[MSG:INFO: Measured waypoint 47]
[MSG:INFO: Waypoint 47 coordinates: X=521.212 Y=242.295]
[MSG:INFO: Measured waypoint 48]
[MSG:INFO: Waypoint 48 coordinates: X=781.819 Y=242.295]
[MSG:INFO: Measured waypoint 49]
[MSG:INFO: Waypoint 49 coordinates: X=781.819 Y=161.530]
[MSG:INFO: Measured waypoint 50]
[MSG:INFO: Waypoint 50 coordinates: X=781.819 Y=80.765]
[MSG:INFO: Measured waypoint 51]
[MSG:INFO: Waypoint 51 coordinates: X=781.819 Y=0.000]
[MSG:INFO: Measured waypoint 52]
[MSG:INFO: Waypoint 52 coordinates: X=781.819 Y=-80.765]
[MSG:INFO: Measured waypoint 53]
[MSG:INFO: Waypoint 53 coordinates: X=781.819 Y=-161.530]
[MSG:INFO: Measured waypoint 54]
[MSG:INFO: Waypoint 54 coordinates: X=781.819 Y=-242.295]
[MSG:INFO: CLBM:[{bl:2782.89, br:2781.31, tr:2804.09, tl:2797.63},{bl:2891.67, br:2682.91, tr:2698.77, tl:2895.58},{bl:2993.59, br:2777.73, tr:2596.42, tl:2813.24},{bl:2897.15, br:2872.53, tr:2697.64, tl:2710.29},{bl:2799.69, br:2970.14, tr:2802.29, tl:2607.21},{bl:2695.76, br:2904.66, tr:2895.05, tl:2675.28},{bl:2781.33, br:2808.2, tr:2812.71, tl:2771.7},{bl:2759.79, br:2757.85, tr:2829.43, tl:2823.44},{bl:2588.28, br:2893.76, tr:2999.82, tl:2697.05},{bl:2598.16, br:2937.82, tr:2997.59, tl:2651.1},{bl:2651.16, br:2981.2, tr:2951.41, tl:2602.22},{bl:2815.86, br:2864.02, tr:2779.41, tl:2716.43},{bl:2989.74, br:2700.94, tr:2604.19, tl:2885.7},{bl:3017.74, br:2653.04, tr:2574.25, tl:2937.79},{bl:2971.62, br:2605.3, tr:2624.03, tl:2978.68},{bl:2933.32, br:2554.33, tr:2669.26, tl:3025.9},{bl:2769.48, br:2630.49, tr:2829.29, tl:2951.65},{bl:2594.82, br:2803.47, tr:2993, tl:2793.01},{bl:2428.14, br:2977.92, tr:3159.39, tl:2643.38},{bl:2379.24, br:3030.12, tr:3212.37, tl:2598.1},{bl:2393.56, br:3073.21, tr:3214.6, tl:2550.35},{bl:2448.05, br:3109.08, tr:3172.29, tl:2500.16},{bl:2491.23, br:3148.82, tr:3131.49, tl:2449.48},{bl:2658.96, br:3107.58, tr:2964.46, tl:2475.93},{bl:2816.99, br:2940.91, tr:2786.44, tl:2641.91},{bl:2984.05, br:2777.09, tr:2609.65, tl:2811.48},{bl:3159.71, br:2619.35, tr:2433.44, tl:2984.1},{bl:3210.6, br:2578.54, tr:2382.49, tl:3035.65},{bl:3241.57, br:2534.06, tr:2357.87, tl:3087.09},{bl:3197.38, br:2483.52, tr:2409.08, tl:3129.43},{bl:3156.55, br:2431.96, tr:2460.16, tl:3169.01},{bl:3139.13, br:2379.85, tr:2488.76, tl:3213.24},{bl:2981.17, br:2375.8, tr:2657.68, tl:3206.09},{bl:2808.2, br:2532.6, tr:2803.84, tl:3050.16},{bl:2636.45, br:2698.98, tr:2959.33, tl:2896.51},{bl:2464.48, br:2875.47, tr:3123.26, tl:2743.15},{bl:2294.36, br:3058.12, tr:3296.84, tl:2591.71},{bl:2246.21, br:3114.11, tr:3347.84, tl:2547.59},{bl:2196.39, br:3172.27, tr:3400.07, tl:2502.63},{bl:2231.83, br:3208.61, tr:3420.99, tl:2455.83},{bl:2280.45, br:3238.98, tr:3419.33, tl:2408.66},{bl:2314.99, br:3271.23, tr:3377.43, tl:2362.21},{bl:2342.45, br:3309.01, tr:3377.39, tl:2316.31},{bl:2482.17, br:3351.89, tr:3217.45, tl:2247.13},{bl:2555.93, br:3186.59, tr:3080.96, tl:2403.45},{bl:2717.49, br:3015.88, tr:2903.46, tl:2565.45},{bl:2874.68, br:2847.82, tr:2720.74, tl:2736.22},{bl:3047.63, br:2687.32, tr:2546.5, tl:2904.27},{bl:3224.93, br:2534.54, tr:2372.57, tl:3074.04},{bl:3275.67, br:2497.49, tr:2322.46, tl:3125.91},{bl:3326.27, br:2457.33, tr:2274.93, tl:3177.61},{bl:3377.23, br:2417.29, tr:2228.03, tl:3229.69},{bl:3404.1, br:2375.14, tr:2229.75, tl:3278.19},{bl:3404.28, br:2323.66, tr:2250.33, tl:3316.91},{bl:3403.66, br:2275.08, tr:2275.54, tl:3357.97}]]
[MSG:ERR: Find Anchors fit failed: rms=5.956mm exceeds limit 5.000mm]
[MSG:ERR: Find Anchors recompute failed]
[MSG:INFO: Find Anchors state reset]
[MSG:INFO: Requesting state change from Finding Anchor to Belts Extended]
I think it fails at the first point already:
I think ovf means overflow?
