# Fusion 360 codes no longer work in GC
**URL:** https://forums.maslowcnc.com/t/fusion-360-codes-no-longer-work-in-gc/8679
**Category:** Fusion 360
**Created:** [February 2, 2019, 10:17pm UTC](https://forums.maslowcnc.com/t/fusion-360-codes-no-longer-work-in-gc/8679 "2019-02-02T22:17:02Z")
**Posts on this page:** 1
**Showing post:** 9
### Author: ![Gero](https://yyz1.discourse-cdn.com/flex031/user_avatar/forums.maslowcnc.com/gero/32/17487_2.png) [@Gero](https://forums.maslowcnc.com/u/Gero)
#### Post date: [June 13, 2019, 10:45am UTC](https://forums.maslowcnc.com/t/fusion-360-codes-no-longer-work-in-gc/8679/9 "2019-06-13T10:45:10Z")
Welcome to the Forum!
> [@Gcode post 6000 lines cutting random places](https://forums.maslowcnc.com/t/gcode-post-6000-lines-cutting-random-places/737/4):
> If I remember right the limit should be 60,000 lines at this point not 6,000. The limit is just there because we had an issue where someone opened a 500,000 (or something crazy like that) line file on a computer that didn’t have enough ram to render the whole file so the computer stopped responding, then every time GC was opened it would lock up the computer so he couldn’t select a different file to open. Maybe the limit should be a setting so you could up it if you needed to? In either case, t…
How many lines does the gcode have?
Edit: If i was using f360 and had that error, i would try to limit precision to 0.1mm (enough for the Maslow) hoping that that will reduce the amount of lines.
Did you use the Maslow post-processor?
Here i found the general drawing precision, but there might be another setting for gcode.
 ![image](https://canada1.discourse-cdn.com/flex031/uploads/maslowcnc/original/2X/4/41bca6d2218619c36c97ac4db8d56abb01a86c53.jpeg)
_[View the full topic](https://forums.maslowcnc.com/t/fusion-360-codes-no-longer-work-in-gc/8679)._
