# Help requested: Improving the Calibration Process
**URL:** <https://forums.maslowcnc.com/t/help-requested-improving-the-calibration-process/20641>\
**Category:** Uncategorized\
**Created:** [April 12, 2024, 6:25pm UTC](https://forums.maslowcnc.com/t/help-requested-improving-the-calibration-process/20641 "2024-04-12T18:25:32Z")\
**Showing post:** 8
**Author:** ![Ethan](https://yyz1.discourse-cdn.com/flex031/user_avatar/forums.maslowcnc.com/ethan/32/23558_2.png) [@Ethan](https://forums.maslowcnc.com/u/Ethan)\
**Post date:** [April 13, 2024, 11:53am UTC](https://forums.maslowcnc.com/t/help-requested-improving-the-calibration-process/20641/8 "2024-04-13T11:53:58Z")
> [@ronlawrence3](#):
> I unplugged it, retract-all, extend all, then jogged around a little after this smaller calibration. Looks like the belts were a little more slack than they were on my last good calibration.
I had this exact same observation. Guessing that the 2x2 calibration is fairly rough like Bar mentioned. Still, for people where calibration will eventually succeed, it’s probably a better starting point that’ll reduce the need to tend belts. Maybe after this rough calibration, the machine gives 10% extra slack than the calculated length on the belts instead of as-needed slack.
I also ran a full 10x9 calibration on 1000x700mm after and that failed, so this isn’t yet the panacea I hoped it would be 😕 (at least for my setup). I’m going to try doing some more simulation and throwing out points to see if that helps.
_[View the full topic](https://forums.maslowcnc.com/t/help-requested-improving-the-calibration-process/20641)._
