# Holey and Makerverse on mega original Maslow not functioning
**URL:** <https://forums.maslowcnc.com/t/holey-and-makerverse-on-mega-original-maslow-not-functioning/15914>\
**Created:** [January 24, 2021, 8:06pm UTC](https://forums.maslowcnc.com/t/holey-and-makerverse-on-mega-original-maslow-not-functioning/15914 "2021-01-24T20:06:18Z")\
**Showing post:** 12
**Author:** ![Sprasher](https://yyz1.discourse-cdn.com/flex031/user_avatar/forums.maslowcnc.com/sprasher/32/7695_2.png) [@Sprasher](https://forums.maslowcnc.com/u/Sprasher)\
**Post date:** [January 25, 2021, 10:26pm UTC](https://forums.maslowcnc.com/t/holey-and-makerverse-on-mega-original-maslow-not-functioning/15914/12 "2021-01-25T22:26:51Z")
of days on and off trying to get things to work. Thanks again and I’ll post what happens.
[![](https://yyz1.discourse-cdn.com/flex031/user_avatar/forums.maslowcnc.com/sprasher/45/7695_2.png)](https://forums.maslowcnc.com/u/Sprasher)
[Sprasher](https://forums.maslowcnc.com/u/Sprasher)
[3m](https://forums.maslowcnc.com/t/holey-and-makerverse-on-mega-original-maslow-not-functioning/15914/12)
I followed the instructions and tried several times deleted and replaced arduino, Makerverse and firmware to make sure I was using the correct versions. Not working still
arduino compiles sketch uploads and says done with the the following message.
Sketch uses 62284 bytes (24%) of program storage space. Maximum is 253952 bytes.
Global variables use 2047 bytes (24%) of dynamic memory, leaving 6145 bytes for local variables. Maximum is 8192 bytes.
Makerverse still has pink box - Firmware: Required version: v51.28 Confirmed Protocol: **Maslow**
At Baud Rate: **57600**
Response Protocol: **Grbl v1.00**
Firmware: **MaslowClassic v1.28**
I don’t know if any of this helps explain what is happening! I am using my tower with win 10 and will bring my laptop over to the shop after lunch and see if that changes anything.
Any advice help?
_[View the full topic](https://forums.maslowcnc.com/t/holey-and-makerverse-on-mega-original-maslow-not-functioning/15914)._
