I saw a message that the sled was not keeping up. How does it know if the sled is keeping up? Does it measure torque on the motors? There are no other optical sensors or anything.
The system knows where it should be based on the movement thatâs requested, and
it knows where it is based on the encoder information, if the two differ by more
than the allowed amount (in the config), it generates this alert
Since we currently do not do any acceleration planning, the system tries to go
from stopped to full speed instantly, and it canât do that (for that matter, the
pid loop doesnât even try to do that), so if you try to go too fast, and have
your limits set to tight, you can easily get this message
Iâve suggested that we instead alert if we spend too much time applying full
power, or if we are at full power and the pid loop is calling for even more
power instead, but that has not been implemented.
what would happen if the sled were removed, how does it know that the sled is not in the correct place. When my machine went haywire, it showed a red placement indicator, and a black one, they are apparently supposed to be on top of each other, but they were very far apart. You say the âencoder informationâ I donât know what the means. I am curious to know specifically how that works.
it only looks at the motor positions
when you tell it to move, it starts tracking where it âshouldâ be, but it
actually doesnât start moving immediately, instead the PID loops starts noticing
that there is an error between where the motors would be if it was where is
âshouldâ be and where the motors are, and adjusts the speed/power ofthe motors.
it doesnât matter if the motors are attached to anything or not, all we know is
the position of the motors as tracked by the encoders on the motors.
This is why the system doesnât know if the chain has jumped or other problems
okay thanks
