I'm thinking about giving up
I’ve hit a series of roadblocks and issues with my kit and find myself pretty whelmed by the experience. Do you get the results you want with your Maslow or did I come to this with unrealistoic expectations?
Anyone want a used and 95% functional kit?
That is hard. I know the feeling. It is a DIY kit and an experiment. The forums and help here keep it fun for me. I have made some cool things. I have also been pretty frustrated. What is your current set up and problem? Can we help?
@aleich dependign which version you have, if willing to ship and depending of the price I would be interrested to end your misery… :slight_smile:
Send me a message if you decide.
Regards
Alexandre
I know the feeling. I have had a series of one-step-forward-two-steps-back.
My original clamp wedges broke so the router was loose in the bases. I had to disassemble, which meant additional parts broke, I think 3 of the 4 posts had portions break off.
I was able to 3D print new clamping wedges, new posts and re-assembled.
I then tried my first gcode test. Somehow my Z home was not taken so the router was above the work when executing the gcode.
I tried to reset Z home, started the gcode again, still the router was above the work, but after a few seconds, a belt got caught in a gap in the rings so I had to stop.
Another dis-assembly. Now the bottom base was cracked at one of the clamping wedge screw holes. A weak point.
I decided to print a turtle style base. This needed some metal spaces to be machined for the clamps, which was easy since I have a metal lathe. The turtle base is thicker so needs 20mm long screws which I then had to order.
I also ordered a 3m length of GT2 belt.
I also designed a 3D printed a spacer to avoid a belt getting trapped between the arms.
So now I have everything, but have not yet re-assembled. I will not be surprised if I break more parts when re-assembling.
I would also be very frustrated if I did not have the 3D printer to be able to take advantage of some of the 3D part designs other forum members have posted.
Dave.
My spring clamps are also broken. I had to Jerry rig some hog rings to make it work. Then on firmware .21. my machine just stopped milling anything round.
I shelved it from July until last week. Super frustrating. I promised people that I could mill things for them and had to eat a lot of crow.
When I worked up the courage to try again, I updated the firmware version to .26 and it’s now working.
I think in your rare circumstance, they should get you a working assembled unit so you can get to work making projects, not fussing over the machine.
