# Initial Frame Design/Setup Guidance
**URL:** <https://forums.maslowcnc.com/t/initial-frame-design-setup-guidance/10316>\
**Category:** No Judgement\
**Tags:** chain, tension, frame, 8020\
**Created:** [June 25, 2019, 11:01am UTC](https://forums.maslowcnc.com/t/initial-frame-design-setup-guidance/10316 "2019-06-25T11:01:30Z")\
**Showing post:** 2
**Post date:** [June 25, 2019, 11:15am UTC](https://forums.maslowcnc.com/t/initial-frame-design-setup-guidance/10316/2 "2019-06-25T11:15:41Z")
Welcome to The Forum!
> [@ThatAirplaneGuy](#):
> Using Siemens NX 11 to create P-Code
Does that also create G-Code for the Maslow? Could you post a simple p-code of circle and square to see what p-code looks like?
> Improved Z-Axis control methods for the sled
If you are planing for a router, check [the-meticulous-z-axis](https://forums.maslowcnc.com/t/the-meticulous-z-axis/3319)
For palm-router or spindle search for the c-beam sleds on the forum.
Kind regards, Gero
_[View the full topic](https://forums.maslowcnc.com/t/initial-frame-design-setup-guidance/10316)._
