Hi, when using the Pause Button in Ground Control, routing stops with a latency of 3-5 seconds. Is this normal? I`m running GC and Firmware V1.11.
I believe that things stop at the end of the current cut, which can take some
time.
This has been my experience. If you are cutting a curve with lots of lines (lines of gcode) it will stop pretty quickly after the pause button is clicked, but if it just started a long straight cut it will stop when it gets to the end of that.
Hi, thanks, that makes sense.
