# M4 Calibration Questions
**URL:** <https://forums.maslowcnc.com/t/m4-calibration-questions/20154>\
**Category:** Uncategorized\
**Created:** [March 12, 2024, 4:34pm UTC](https://forums.maslowcnc.com/t/m4-calibration-questions/20154 "2024-03-12T16:34:34Z")\
**Showing post:** 47
**Author:** ![KDB](https://avatars.discourse-cdn.com/v4/letter/k/7feea3/32.png) [@KDB](https://forums.maslowcnc.com/u/KDB)\
**Post date:** [May 30, 2024, 2:18am UTC](https://forums.maslowcnc.com/t/m4-calibration-questions/20154/47 "2024-05-30T02:18:09Z")
Serial Messages
[GC:G0 G54 G17 G21 G90 G94 M5 M9 T0 F0 S0]
[MSG:INFO: FluidNC v0.74 (Maslow-Main-dddcbc15-dirty)]
[MSG:INFO: Compiled with ESP32 SDK:v4.4.4]
[MSG:INFO: Board Maslow]
[MSG:INFO: UART1 Tx:gpio.1 Rx:gpio.2 RTS:NO\_PIN Baud:115200]
[MSG:INFO: SD Card cs\_pin:gpio.10 detect:NO\_PIN freq:8000000]
[MSG:INFO: Axis count 3]
[MSG:INFO: Motor0]
[MSG:INFO: Config messages ran]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: tmc\_2209 UART1 Addr:0 Step:gpio.15 Dir:gpio.16 Disable:NO\_PIN R:0.110]
[MSG:INFO: Motor1]
[MSG:INFO: tmc\_2209 UART1 Addr:1 Step:gpio.46 Dir:gpio.38 Disable:NO\_PIN R:0.110]
[MSG:INFO: C\<Alarm|MPos:0.000,0.000,0.000|FS:0,0|Ov:100,100,100\>
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Connecting to STA SSID:hudson]
[MSG:INFO: Connecting.]
[MSG:INFO: Connecting…]
[MSG:INFO: Connected - IP is 192.168.0.19]
[MSG:INFO: WiFi on]
[MSG:INFO: Start mDNS with hostname:[http://maslow.local/](http://maslow.local/)]
[MSG:INFO: SSDP Started]
[MSG:INFO: Bottom Left pulled tight with offset -1395.251]
[MSG:INFO: Top Left pulled tight with offset -1432.806]
[MSG:INFO: Bottom Right pulled tight with offset -1736.562]
[MSG:INFO: Top Right pulled tight with offset -1758.463]
[MSG:INFO: Zeroing z-axis position]
[MSG:INFO: Center point deviation: TL: 0.186 TR: 0.332 BL: -3.967 BR: -3.631]
[MSG:ERR: Unable to move safely, stopping calibration]
_[View the full topic](https://forums.maslowcnc.com/t/m4-calibration-questions/20154)._
