I’ll check that. Thank you
Just installed new board. Now i’m getting top left encoder failure. I’ve swapped cables around and the problem follows the encoder. ![]()
Thoughts? Do I need a new encoder now?
Maslow-serial.log.crdownload (10.8 KB)
Also getting these:
[MSG:ERR: Invalid setting or command: /Maslow_trX]
error:3
[MSG:ERR: Invalid setting or command: /Maslow_trY]
error:3
[MSG:ERR: Invalid setting or command: /Maslow_trZ]
error:3
[MSG:ERR: Invalid setting or command: /Maslow_tlX]
error:3
[MSG:ERR: Invalid setting or command: /Maslow_tlY]
error:3
[MSG:ERR: Invalid setting or command: /Maslow_tlZ]
error:3
[MSG:ERR: Invalid setting or command: /Maslow_brX]
error:3
[MSG:ERR: Invalid setting or command: /Maslow_brZ]
error:3
[MSG:ERR: Invalid setting or command: /Maslow_blZ]
error:3
And:
[MSG:WARN: Encoder read failure on Top Left]
[MSG:WARN: Encoder not found on Top Left]
[MSG:WARN: Magnet not detected on Top Left]
[MSG:INFO: All tests passed on Top Right]
[MSG:INFO: All tests passed on Bottom Left]
[MSG:INFO: All tests passed on Bottom Right]
[MSG:ERR: Encoder not found on Top Left]
[MSG:INFO: Zm=2.000mm, Z home=0.000mm, Z position=2.000mm]
The magnetic is loose or the magnet is not near the encoder chip (upside down).
one problem a few people have seen is the pins on the bottom of the encoder
hitting the bearing and shorting out. clippng the pins shorter solves this
problem
error:3
error:3
error:3
error:3
error:3
error:3
error:3
error:3
error:3
these coudl be that your index.html.gz and firmware don’t match check their
versions
Is it a nightmare to get at the board?
How can I check the index version? I’m pretty sure I got both new ones to install from Github. Definatly have firmware 1.25.
you have to disassemble the arm to get at the bottom of the encoder board (I
don’t think you can get at it from the outside, but check
go to settings ->test and in the log section it will log both the index and
firmware versions. If you haven’t done a full browser reload after an upgrade,
your browser may still be using the old version
Just ordered a new encoder. I don’t want to have to disassemble multiple times. I’ll update when I install it. ![]()
According to the serial log, you have two different versions index.html gz is 1.04 and firmware is v1,25
Serial Messages
Index.html Version: 1.04
[MSG:INFO: FluidNC v1.25.0]
To load the latest index.html.gz download the file from
Releases · MaslowCNC/Maslow_4
make sure it is not unzipped, then go to the FluidNC pulldown, select the 1st Green button (local files) and upload the file from where it was saved (Generally downloads directory for Windows)
This won’t fix the encoder problem, but it should get rid of the error messages.
Thank you very much! I’ll try that tomorrow. I wonder if in the future they could be made to update as a single package to avoid this type of thing?
It already is, the 2nd Green button was added a couple of months ago, just not sure if it appears on the version you are running. If it’s there use that one.
Check for updates online and run automatically
You may also need to replace maslow.yaml file. Make a backup first.
How did you go?
Sorry. Got busy. Im going to wait for my new encoders to arrive now. Will be sure to update this topic when that happens
All working with new encoder!
Wow! I give maslow 10 on innovation and 1 on serviceability. Hope i never have to do that again.
