Has anybody developed a proper octorprint plugin that interacts with the Maslow Cnc? I have attempted to use their better Grbl without any reliable results. My final goal is to have a single pi running two instances of Octoprint, one for the Cnc and one for a 3d printer, though not operating simultaneously.
Maslow has many custom commands that octoprint does not support. If using the classic mega controller, webcontrol is the software for a web enabled setup. If using the m2 with the due controller, use makerverse with guest mode enabled. While it is true the grbl system should take gcode from any grbl sender, Maslow is a modified setup, so it isn’t recommended. The v4 that is in dev may be a better option for that.
