Where do you input z offset for material thickness or anchor locations?
Is it possible to step through g code cutting instructions. I used Krabzcam to generate g codes and it separated out cutting operations but when I load them into maslow it doesn’t seem like I can easily pause between operations or run just one at a time. I know I could load each path separately I didn’t know if there was a way to step through them on the machine.
How important is it to screw down material or block it in place? I don’t want to interfere with the sled. Also how important is it to leave bridges when cutting pieces entirely free?
Thank you for any advice. Exciting to see it finally moving on its own.
right now, you have to go to the fluidnc tab, click the right button (config
settings) and enter it there.
them into maslow it doesn¢t seem like I can easily pause between operations or
run just one at a time. I know I could load each path separately I didn¢t know
make each phase a separate file, then just load and run the files one at a time.
How important is it to screw down material or block it in place? I don¢t want
‘it depends’
if your workpiece moves (or the parts shift after being cut free) that can
completely ruin your work
but sometimes your parts are heavy enough and have enough friction that you
don’t need to screw them down (using the silicon shelf liner between the parts
that are fixed and those that aren’t can help here)
you are correct about worrying about interfering with the sled movement. you
also want to be sure that you don’t run the bit into steel.
There are plastic nails available, and brass screws, both of which you can cut
through without damage
there is also double-sided tape.
the pieces that you cut free also have the force of the bit being applied to
them, so they are more likely to move, so not cutting it completely free is a
good idea.
some people use tabs, some people plan to not quite cut all the way through, and
then use a hand-held router with a flush cut but to cut the last of the way
through.
in the section where the anchor locations are stored, there are Z values for each anchor
ahead of that there is a wasteboard setting
next to the wasteboard setting is the workpiece thickness setting
you can actually split/combine these however you want, they all get added together
But the per-arm Z values are the distance from the arm to the bottom of the sled, you can leave those alone if your anchors are all at the same height
Then you can use the wasteboard setting for things that are fixed on the frame (i.e. put in the distance from the bottom of the belt ends at the anchor to the top of the wasteboard)
and finally, just adjust the workpiece thickness for your workpiece.
Which of those would I change in the fluid settings menu to change the z
positions?
I would leave the per-arm Z values alone
I would use the wasteboard setting to put in the distance from the bottom of the
belt ends at the anchors to the top of the wasteboard (as I look at your frame,
this should just be the thickness of your wasteboard)
then I would do calibration just on the wasteboard.
When cutting, I would put in the workpiece thickness (although this is less
important than having theings right when running calibration)
