# Motor encoder question
**URL:** <https://forums.maslowcnc.com/t/motor-encoder-question/12733>\
**Created:** [March 24, 2020, 12:15pm UTC](https://forums.maslowcnc.com/t/motor-encoder-question/12733 "2020-03-24T12:15:34Z")\
**Showing post:** 25
**Post date:** [March 25, 2020, 1:05pm UTC](https://forums.maslowcnc.com/t/motor-encoder-question/12733/25 "2020-03-25T13:05:40Z")
> [@Z-axis Pitch calculated at 99!](https://forums.maslowcnc.com/t/z-axis-pitch-calculated-at-99/11697):
> Hi, I’ve just cut my first piece on my just assembled MetalMaslow. It’s cutting great and surprisingly accurate. The only trouble I had was getting the pitch of the Z-axis correct. I set the Z-axis pitch at 8, as suggested in the forum. However when I moved it 0.5mm down it actually moved 6.4mm. A factor of 12 times more! So after some calculations I ended up with a pitch of 99! I changed the Z axis pitch setting in GC to 99 and got the correct displacement. Of course I can live with this setti…
I think what might be going on is that @metalmaslow is telling people what value to use for pitch to make the system work using the stock motor encoder’s setting. All that matters is pitch\*encoder counts (edit: might be encoder counts / pitch) to come out to the correct number. Try 99 and see if it works.
_[View the full topic](https://forums.maslowcnc.com/t/motor-encoder-question/12733)._
