Ran the cut test and noticed only the vertical cuts were made. It never passed over that area at all. Should i just use top of cut 2?
Can you send a picture of the sled?
Check the play in the router collar and wax the body of the router. I used bees wax. I see you have some buggies but it’s hard to see in the picture provided what and how it’s doing. Make sure it is not getting stuck. You could loosen the coupler and check it by hand.
Only green bungee is in use for keeping z axis inline with worm screw. The issue with cut 5 seemed program based. I was following machine as it went through test and it never even attempted traveling to where cut 5 should have been
I’d bee surprised if you didn’t
