Hey gang, you guys seem like a good crew to ask. Sorry if this breaks any rules, feel free to delete if it does.
I’m trying to work up a way to have some failure indicator lights in a 12v light circuit. I have (5) 48w incand. 12v fixtures on individual circuits. I would like to have an indicator light for each circuit that lights on filament failure.
I tried a cheapo DC current sensing relay and haven’t had much luck, perhaps due to a bad unit. While I wait for a new one, I was thinking, this might be something that arduino would be good for. Or perhaps there is another solution I’m unaware of.
If anyone has any input, I’d be happy to have some help.
put a LED in parallel with the incandecent bulb, when the bulb fails, the LED
will see 12v and light up, when the bulb is still working, almost all the
current will go through the bulb and the LED will be dim, if on at all (and a
resistor on the LED will make this even more so)
Awesome, thank you both! Moose, that sounds simple enough. David, could it really be that simple? I’ll give it a try tomorrow, I’ll have to find my LED stash.
Should have thought of that @dlang. Any bulb, even an incandescent would work. You might need a couple sensed bulbs in series or the LED will see full voltage regardless if the sensed bulb burns out or not.
you can now buy fuses that work like this, they have a LED in parallel with the
fuse element and the LED lights when the fuse blows. An incandecent light will
have more resistance than a fuse element, but it should still be tiny compared
to the LED
I found this double throw reed relay on the popular auction site. You’d need to experiment with winding a coil around it to see how many turns of wire you’d. Speced relays would tell you in ampere turns, but might be hard to find a datasheet for these.
That seems like an interesting solution, and right up my alley. Unfortunately, this project has a deadline, and it’s almost dead. So, a reed relay is different than a reed switch?
You’re quick! I just re-read your first post and was going to say that. Maybe a few extra turns for grins, don’t need very large gauge wire for 4A. 20/4 turns, 10-15 would be more than enough.
40+ years of electronics and programming has made me a fan of old school for stuff that needs to last for years. I did our 6 zone primary/secondary home boiler controls with a box of relays instead of a PLC…
