# Right motor calibration
**URL:** <https://forums.maslowcnc.com/t/right-motor-calibration/10165>\
**Created:** [June 9, 2019, 4:41pm UTC](https://forums.maslowcnc.com/t/right-motor-calibration/10165 "2019-06-09T16:41:20Z")\
**Showing post:** 8
**Post date:** [June 10, 2019, 2:35am UTC](https://forums.maslowcnc.com/t/right-motor-calibration/10165/8 "2019-06-10T02:35:58Z")
> [@Set your 12 o'clock position with a level... because](https://forums.maslowcnc.com/t/set-your-12-oclock-position-with-a-level-because/8445):
> About setting the 12 o’clock position with Ground Control, Do you see what I mean? [12oClock] I find it difficult to visually set it straight. Now you might wonder “How straight is straight enough?” Well 1/12 of a sprocket tooth distance is 3 degree. That is: [12oClock\_ticks] And this causes about 0,5 mm chain position error on a sprocket. If both sprockets have an error around 3 degree off. They either go opposite (one too high, the other too low) and the X, Y workspace is shifted like t…
_[View the full topic](https://forums.maslowcnc.com/t/right-motor-calibration/10165)._
