I picked up some 4x4 plywood that used to be shipping crates. Its 16/17th thick. Was thinking of making the Roxanne chairs from open desk. Will this work? i believe the pockets are designed for 3/4 plywood.
With a different thickness you will have to go through the process using a CAD program to adjust the files (where the pieces need to fit together) for the thickness of your material. Then it should work.
Thought so thanks. Will play around with the joints.
