I’m wondering if I can cut solid surfaces, like for a countertop with the maslow.
Any suggestions on bits or experience with this?
Thanks
Thanks
Jumping in here because I plan to do this in the future. I do know that you should use an upcut fluted bit the amount of tips may not matter and RPM can differ it is mainly keeping the chips out of the cut so they don’t get hot and melt to the bit.
you can cut anything that a router will cut. do you have a router bit that will
cut that particular surface? (some are easy, some are near impossible, depends
on the surface)
