Unable to Connect to Home Network after Firmware update
Hello all!
I am running into some odd connectivity issues between my home network and Maslow. I have been getting around those issues by using the backup Maslow network.
The connectivity issues that I have been running into started once I upgraded Maslow to the newest firmware. My network has a space and a comma in the ssid. For whatever reason, Maslow is no longer able to parse the network. It concatenates the name into one string.
My router allows me to create a guest network, so I made a 2.4ghz network called Garage and made an accompanying password. Even now Maslow seems unable to connect.
I am also still confused in regards to the troubleshooting lights. All of the posts that I have seen say that the indicator LED should be flashing to indicate that it connects/ isn’t able to connect, but when my machine starts up, the light never blinks and just lights up. It still creates the Maslow WIFI network as well.
I may just be making this all too complicated. My Maslow works and can be calibrated, but not being able to connect to it from my home network slows things down.
Any guidance would be greatly appreciated!
Green LED is power, Blue LED flashes when it finds a valid network (flashes out the IP address) red LED indicates an alarm.
Generally a guest network has no local network access.
Try setting network via FluidNC, Flash Settings
If that doesn’t work, can you change your SSID in your Router?
SSID restrictions were put in place in January. If you update to the following, you should be able to update the SSID with spaces and commas. It also contains some unreleased changes, which are still being tested, so if you have any problems, please report back.
index.html.gz (135.7 KB)
firmware.bin (1.9 MB)
Did this help?
