If you have a z-axis you may want to prepare the system for the automatic zeroing function
Very awesome functionality for any tool changes and resetting the zero.
You need to attach two wires to the control board and be able to feed them out to the router.
You need a thin board with a conductive surface ( I am using a wooden board with a HVAV aluminum tape strip on it)
I also use a clothes pin and a magnet to attach the wire to a flap of the tape and the router, respectively.
I can get you more details and pictures but am at work right now.
This is an easy to implement excellent addition.
I am sure there was a description in this forum somewhere as well.
Hey @bar any idea what the grease is inside the gearboxes? It looks like some graphite concoction, but I’m not sure on the specifics. The next time I have to open these things up I’ll probably want to fully clean them out and regrease them.
Huh. I was hoping the gray tint to the grease was from graphite and not wear on the gears.
Next time I open them up, I’ll stick 'em in the ultrasonic cleaner and regrease the whole deal. I think it was a tiny bit of grit that was gunking up that first worm drive gear.
