# Weights for chain tension
**URL:** <https://forums.maslowcnc.com/t/weights-for-chain-tension/9718>\
**Category:** Frame\
**Created:** [May 2, 2019, 5:31pm UTC](https://forums.maslowcnc.com/t/weights-for-chain-tension/9718 "2019-05-02T17:31:52Z")\
**Showing post:** 1
**Post date:** [May 2, 2019, 5:31pm UTC](https://forums.maslowcnc.com/t/weights-for-chain-tension/9718/1 "2019-05-02T17:31:52Z")
I was having problems with the elastic cord not keeping enough tension on the slack and the chains twisting as a result, I made a quick trip to home depot and got the cloathsline pullys and a couple conduit sweeps, here is the result (works much better, but I need to relocate the end of the chain to handle the full work area)
I didn’t bother relocating the metal pulleys from the old arrangement. the screw in the center is to hold the sled out of the way.
the paracord seems to have no trouble wrapping around the edge of the beam to get to the sweeps attached to the bottom of the beam.
 ![IMG_20190430_210228](https://canada1.discourse-cdn.com/flex031/uploads/maslowcnc/original/2X/6/6681f415dc00d0e1cd28664af97a80874442bbb4.jpeg)
pulley
$2.38 ea [https://www.homedepot.com/p/Everbilt-2-1-2-in-Clothesline-Pulley-72692/206094288](https://www.homedepot.com/p/Everbilt-2-1-2-in-Clothesline-Pulley-72692/206094288)
conduit
$0.64 ea [https://www.homedepot.com/p/Carlon-1-2-in-90-Degree-Schedule-40-PVC-Belled-End-Standard-Radius-Elbow-UA9ADB-CTN/100404151](https://www.homedepot.com/p/Carlon-1-2-in-90-Degree-Schedule-40-PVC-Belled-End-Standard-Radius-Elbow-UA9ADB-CTN/100404151)
_[View the full topic](https://forums.maslowcnc.com/t/weights-for-chain-tension/9718)._
