Serial Messages
Index.html Version: v1.23.0
[MSG:INFO: FluidNC v1.23.0]
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 5]
[MSG:INFO: Axis A (-4000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis B (-4000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis C (-4000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis D (-4000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: tmc_2209 UART1 Addr:0 Step:gpio.15 Dir:gpio.16 Disable:NO_PIN R:0.11]
[MSG:INFO: Motor1]
[MSG:INFO: tmc_2209 UART1 Addr:1 Step:gpio.46 Dir:NO_PIN Disable:NO_PIN R:0.11]
[MSG:INFO: Connecting to STA SSID:CreativeCity]
[MSG:INFO: Connecting.]
[MSG:INFO: Connecting..]
[MSG:INFO: Connecting…]
[MSG:INFO: Connected - IP is 192.168.1.22]
[MSG:INFO: WiFi on]
[MSG:INFO: Start mDNS with hostname:http://maslow.local/\]
[MSG:INFO: WebSocket send protection active (canSend() checks enabled)]
[MSG:INFO: SSDP Started]
[MSG:ERR: Not handling localfs subdirectories]
Grbl 1.23 [FluidNC v1.23.0 (wifi) ‘$’ for help]
[MSG:INFO: ‘$H’|‘$X’ to unlock]
[MSG:INFO: Current z-axis position loaded as: 4.000]
[MSG:INFO: Saved belt positions in NVS are marked as stale/invalid (value=0) - machine will remain in UNKNOWN state until belts are calibrated/extended]
[MSG:INFO: Starting Maslow Version v1.23.0-dirty]
[MSG:INFO: Maslow_Retract_Current_Threshold: 1100]
[MSG:INFO: Maslow update loop registered with hardware watchdog]
[MSG:INFO: Zm=4.000mm, Z home=4.000mm, Z position=0.000mm]
Retract All
[MSG:INFO: Succeeded]
[MSG:INFO: Top Left pulled tight with offset -1917.543]
[MSG:INFO: Bottom Right pulled tight with offset -1937.737]
[MSG:INFO: Bottom Left pulled tight with offset -1903.855]
[MSG:INFO: Top Right pulled tight with offset -1917.382]
Extend All
[MSG:WARN: Encoder I2C error -103 on Bottom Left]
[MSG:WARN: Bad connection on Bottom Left encoder, failed to read 1 times in the last second]
[MSG:ERR: Emergency stop. Update function not being called enough. 1002ms since last call]
Serial Messages
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: WiFi on]
Retract All
Extend All
Retract All
[MSG:INFO: Top Left pulled tight with offset 0.000]
[MSG:INFO: Top Right pulled tight with offset -224.291]
[MSG:INFO: Bottom Left pulled tight with offset -0.021]
[MSG:INFO: Bottom Right pulled tight with offset -684.769]
Extend All
[MSG:WARN: Encoder read failure on Top Left]
[MSG:WARN: Bad connection on Top Left encoder, failed to read 1 times in the last second]
[MSG:WARN: Bad connection on Top Left encoder, failed to read 31 times in the last second]
[MSG:ERR: Failure on Top Left encoder, failed to read 160 times in the last second]
[MSG:ERR: Failure on Top Left encoder, failed to read 161 times in the last second]
[MSG:ERR: Failure on Top Left encoder, failed to read 159 times in the last second]
[MSG:WARN: Encoder read failure on Bottom Left]
[MSG:ERR: Failure on Top Left encoder, failed to read 166 times in the last second]
[MSG:ERR: Failure on Bottom Left encoder, failed to read 121 times in the last second]
[MSG:ERR: Failure on Bottom Left encoder, failed to read 164 times in the last second]
[MSG:ERR: Failure on Bottom Left encoder, failed to read 163 times in the last second]
[MSG:ERR: Failure on Bottom Left encoder, failed to read 160 times in the last second]
[MSG:ERR: Failure on Bottom Left encoder, failed to read 154 times in the last second]
[MSG:WARN: Bad connection on Bottom Left encoder, failed to read 48 times in the last second]
currently up against a problem when one of the belts extends 1cm then locks in place
probably similar cause
what do you recommend I replace?
Serial Messages
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Connected - IP is 192.168.1.4]
[MSG:INFO: WiFi on]
[MSG:INF9 UART1 Addr:0 Step:gpio.15 Dir:gpio.16 Disable:NO_PIN R:0.11]
[MSG:INFO: Motor1]
[MSG:INFO: WiFi on]
[MSG:WARN: Maslow Z position warning: Z position out of range, check Z home is valid (Z home=0.000mm, Z position=-11.000mm, Z home + Z position=-11.000mm). Valid range is 0 to 72mm inclusive. Power cycling Maslow may clear error.]
[MSG:INFO: Current z-axis position loaded as: -11.000]
[MSG:INFO: Maslow_Retract_Current_Threshold: 1400]
[MSG:INFO: Zm=-11.000mm, Z home=0.000mm, Z position=-11.000mm]
Retract All
[MSG:INFO: Top Right pulled tight with offset 0.011]
[MSG:INFO: Bottom Right pulled tight with offset -0.107]
[MSG:INFO: Bottom Left pulled tight with offset -0.140]
[MSG:INFO: Top Left pulled tight with offset -0.580]
Extend All
Which belt is it that is doing that? Is it the bottom left? My first instinct would be to just unplug that cable and maybe blow on it and put it back and see if that fixes it
