There are so many variables it depends on, the better you calibrate, the wider and higher you go.
Here is just a sample image
It’s not clear lines as in the picture, more a transition area where it gets worse.
In the white, with a accurately built sled and centred bit, you should be able to get under 1mm accuracy.
Kind regards, Gero
