Calibration code / understanding
I appreciate all the thoughts you have put into this. I can follow most of it.
Throwing out another idea. Think of when installing software on a PC. There is usually a standard setup (ie easier mode, less prompts) or an advanced/define options mode.
That might be a way also to let the user decide if they want to risk choosing manual definitions.
Dano
I’ve just about surfaced after a 3 days of demoing all of the boardgames :laughing:
Yeah, I tend to agree, though my take (and @bar likely will disagree) is the standard setup should still be asking for info / measurements from the user, they should just be hand-holding the user through it all like a Setup Wizard, and sanity checking / validating them - with the advanced being documented but letting the user do what they want.
Here’s another simple to do one from looking at a thread this morning:
I don’t think the logs have the values from the Maslow.yaml (until it sets some at the end)?
I’d dump at least the user-modifiable ones (Z offsets, Vert/Horizontal - actually i’ll just put below) both immediately when the user hits the Calibrate Button, and after you’ve written them at the end of calibration (input/output logging basically).
My experience is users i’ve had are about 10x more likely to mangage/bother to capture 1 log 1 way, then 2 logs 2 ways.
(I’d just have this / these fields dumped in the log:
Maslow_vertical: false
Maslow_calibration_grid_width_mm_X: 1200.000000
Maslow_calibration_grid_height_mm_Y: 800.000000
Maslow_calibration_grid_size: 7
Maslow_tlX: -9.100000
Maslow_tlY: 2276.100098
Maslow_trX: 2910.899902
Maslow_trY: 2277.899902
Maslow_blX: 0.000000
Maslow_blY: 0.000000
Maslow_brX: 2926.600098
Maslow_brY: 0.000000
Maslow_tlZ: 90.000000
Maslow_trZ: 50.000000
Maslow_blZ: 30.000000
Maslow_brZ: 68.000000
Maslow_Retract_Current_Threshold: 900
Maslow_Calibration_Current_Threshold: 900
Maslow_Acceptable_Calibration_Threshold: 0.450000
Maslow_Extend_Dist: 1700.000000
Maslow_beltEndExtension: 30.000000
Maslow_armLength: 123.400002
Maslow_Scale_X: 1.000000
Maslow_Scale_Y: 1.000000
Not much progress on this, got distracted by:
Everything’s better under the C (a quick poke at the frame flex value).
But I did try a quick manual iteration of doing short descents (100) multiple times, weighted average of the results, then using that as the input for another round, with the area the initial sample is taken from decreasing each time.
I started with a roughly-right frame measurement (in unstretched-belt-mm), and only did 10 samples-with-100-descents in each step as this seemed like the lowest I was likely to get anything from. And I did 3 iterations, sample ± 50mm in the first, then ±25mm, then ±12mm.
Fitness TL X TL Y TR X TR Y BL X BL Y BR X BR Y
1st round 100
plus minus 50mm
0.5715 -10.3 2314 2868.6 2327.9 0 0 2890.1 0
0.5041 3.9 2330.4 2875.4 2320.8 0 0 2890.9 0
0.4197 7.8 2319.8 2899 2291.6 0 0 2903.3 0
0.3712 7.6 2293.5 2924.9 2258.8 0 0 2924.6 0
0.6179 -16 2298.2 2878.9 2315.7 0 0 2897.2 0
0.4399 -10.7 2264.1 2898.2 2292.5 0 0 2929.9 0
0.2687 14 2307.9 2924.8 2258.9 0 0 2918.8 0
0.6162 -10.9 2286.6 2887.6 2305.1 0 0 2911.5 0
0.6118 -0.8 2324.3 2876.3 2319.3 0 0 2891.3 0
0.9893 -7.2 2273.6 2910.8 2276.3 0 0 2925.8 0
Weight total
5.4103
Weighted
-5.88645 1322.451 1639.4049 1330.39485 0 0 1651.69215 0
1.96599 1174.75464 1449.48914 1169.91528 0 0 1457.30269 0
3.27366 973.62006 1216.7103 961.78452 0 0 1218.51501 0
2.82112 851.3472 1085.72288 838.46656 0 0 1085.61152 0
-9.8864 1420.05778 1778.87231 1430.87103 0 0 1790.17988 0
-4.70693 995.97759 1274.91818 1008.47075 0 0 1288.86301 0
3.7618 620.13273 785.89376 606.96643 0 0 784.28156 0
-6.71658 1409.00292 1779.33912 1420.40262 0 0 1794.0663 0
-0.48944 1422.00674 1759.72034 1418.94774 0 0 1768.89734 0
-7.12296 2249.27248 2879.65444 2251.94359 0 0 2894.49394 0
Weighted Totals
-22.98619 12438.62314 15649.72537 12438.16337 0 0 15733.9034 0
Weighted Averages
-4.248598044 2299.063479 2892.579962 2298.978498 0 0 2908.138809 0
2nd round 100
plus minus 25mm
0.8812 12 2308.4 2881.8 2280 0 0 2932.3 0
0.8812 -1.6 2304.6 2868.4 2314.6 0 0 2930.1 0
0.8812 -11 2308.7 2898.3 2308.1 0 0 2927.9 0
0.8812 14.7 2324 2869.7 2273.5 0 0 2931.8 0
0.9488 -5.5 2285.4 2909.1 2278.4 0 0 2918 0
1.0708 -7.2 2294.5 2895.3 2295.6 0 0 2909.1 0
0.8877 -4.3 2308.1 2888.3 2304.3 0 0 2901 0
0.8812 5.7 2311.3 2915.8 2277.1 0 0 2908.8 0
0.8812 -5.2 2276.4 2908 2307.9 0 0 2904.9 0
0.9302 -4.6 2292 2904.8 2283.8 0 0 2913.6 0
Weight total
9.1247
Weighted
10.5744 2034.16208 2539.44216 2009.136 0 0 2583.94276 0
-1.40992 2030.81352 2527.63408 2039.62552 0 0 2582.00412 0
-9.6932 2034.42644 2553.98196 2033.89772 0 0 2580.06548 0
12.95364 2047.9088 2528.77964 2003.4082 0 0 2583.50216 0
-5.2184 2168.38752 2760.15408 2161.74592 0 0 2768.5984 0
-7.70976 2456.9506 3100.28724 2458.12848 0 0 3115.06428 0
-3.81711 2048.90037 2563.94391 2045.52711 0 0 2575.2177 0
5.02284 2036.71756 2569.40296 2006.58052 0 0 2563.23456 0
-4.58224 2005.96368 2562.5296 2033.72148 0 0 2559.79788 0
-4.27892 2132.0184 2702.04496 2124.39076 0 0 2710.23072 0
Weighted Totals
-8.15867 20996.24897 26408.20059 20916.16171 0 0 26621.65806 0
Weighted Averages
-0.894130218 2301.034442 2894.14453 2292.257467 0 0 2917.537898 0
3rd round 100
plus minus 12mm
1.0259 -4.5 2291.4 2902.7 2286.6 0 0 2914.4 0
0.9889 -4.5 2291.9 2903.3 2285.6 0 0 2913.8 0
0.9364 -3.4 2300.3 2897.2 2293.3 0 0 2908.2 0
0.8446 -1.8 2301.4 2898.4 2291.9 0 0 2908.8 0
0.8978 -5.6 2307.4 2888.2 2304.1 0 0 2900.2 0
1.003 -6.4 2300.7 2891.3 2300.5 0 0 2904.7 0
0.8056 -1.1 2301.8 2899 2291.1 0 0 2909.1 0
1.0501 -5 2293.5 2900.2 2289.4 0 0 2912.1 0
0.8971 -3.5 2306.8 2890.2 2302 0 0 2902.9 0
1.0043 -5.3 2287.3 2906.4 2281.8 0 0 2916.6 0
Weight total
9.4537
Weighted
-4.61655 2350.74726 2977.87993 2345.82294 0 0 2989.88296 0
-4.45005 2266.45991 2871.07337 2260.22984 0 0 2881.45682 0
-3.18376 2154.00092 2712.93808 2147.44612 0 0 2723.23848 0
-1.52028 1943.76244 2447.98864 1935.73874 0 0 2456.77248 0
-5.02768 2071.58372 2593.02596 2068.62098 0 0 2603.79956 0
-6.4192 2307.6021 2899.9739 2307.4015 0 0 2913.4141 0
-0.88616 1854.33008 2335.4344 1845.71016 0 0 2343.57096 0
-5.2505 2408.40435 3045.50002 2404.09894 0 0 3057.99621 0
-3.13985 2069.43028 2592.79842 2065.1242 0 0 2604.19159 0
-5.32279 2297.13539 2918.89752 2291.61174 0 0 2929.14138 0
Weighted Totals
-39.81682 21723.45645 27395.51024 21671.80516 0 0 27503.46454 0
Weighted Averages
-4.211771053 2297.878762 2897.86118 2292.415156 0 0 2909.280445 0
The output of the 3rd round (equiv to 3000 descents in the normal algorithm) Is pretty good, the TLX is slightly off - looking at the data it looks like you get a spread of potential values, possibly bimodal, which is interesting. I have wondered if doing a grid of points is giving us sampling artifacts and we should be doing (still stratified) random sample points for the calibration, that’s for another day though.
That IS interesting, I am curious to see if that pattern holds up as something which consistently happens
Throwing this message in here because I like the research that @RandomDave is doing, but I have a profoundly different idea for how to perform the actual calibration, which would feed into different ways to establish frame flex / belt stretch as well.
I’ve had a poke around inside the FluidNC code for this, but I wanted to get pointers (probably from @bar ) as to where in the code I should be looking to do what I need to.
I can plainly see the code to move one belt at a time. My need, however, is to retract / extend two belts simultaneously, while the other two don’t move (or at most spool out a little bit).
Check out the the function for taking a measurement. That’s basically exact what it does, two belts are held steady and the other two retract. (It wouldn’t be too hard to modify for different behavior)
Lots of different approaches are good - there’s a decent chance what i’m trying won’t come to anything, and you never know what crossovers will give us what we want too :grin:
What you want to do i’d definitely be interested in doing too!
@bar or @md8n (or anyone else) - just a sanity check.
The point data output to serial, like:
CLBM:[{bl:1844.02, br:1863.70, tr:1853.19, tl:1853.05},{bl:1963.27, br:1742.44, tr:1738.79, and so on.
Has that had any projection done on it already (via the ZOffsets or anything else) or is it literally the belt length via the magnet sensor converted to mm?
(this is on recent FW - 1.06 though I doubt it’s changed recently)
These values have already been projected into the XY plane accounting for the height of the z-axis.
Ahhhhh, that might account for some funkiness i’m seeing with a specific calibration run, thanks!
I’ve been playing with a bit of classic Monte Carlo stuff (technically I think it would count as MCMC, but with a binary yes/no rather than a weighted step), that seems to be working well in my small experiments.
If we’re in the right ballpark for the answer, just sampling around what we’ve got and keeping any higher fitness gets me better fitness than I was seeing from the algorithm.
We can use a descending radius to sample from too to focus in those samples once we’re close.
That said, we need to be careful we don’t fall in the same trap of getting stuck on a non-optimal minima. And we need to get fairly close to a minima to start. What seems to work quite well is to marry a short run of the original algorithm (up to 1000 steps) with some MC, and loop that, keeping the current best but kicking off new descents for a decent distance away.
It’s scrappy experiment code, but this is working quite well for me:
const compute1kButton = document.getElementById('compute-1k-button');
compute1kButton.addEventListener('click', () => {
    currentBest = JSON.parse(JSON.stringify(initialGuess));
    for(let outer = 0; outer < 10; outer++){
        clearCanvas();
        guessThisTime = JSON.parse(JSON.stringify(currentBest));
        guessThisTime.tl.x = guessThisTime.tl.x + (Math.random() * 10) - 5;
        guessThisTime.tl.y = guessThisTime.tl.y + (Math.random() * 10) - 5;
        guessThisTime.tr.x = guessThisTime.tr.x + (Math.random() * 10) - 5;
        guessThisTime.tr.y = guessThisTime.tr.y + (Math.random() * 10) - 5;
        guessThisTime.br.x = guessThisTime.br.x + (Math.random() * 10) - 5;
        guessThisTime = computeLinesFitness(measurements, guessThisTime);
        guessThisTime = findMaxFitness(guessThisTime, measurements);
        printResults(guessThisTime);
        if(1/guessThisTime.fitness > 1/currentBest.fitness){
            console.log("Fitness: " + 1/guessThisTime.fitness);
            currentBest = JSON.parse(JSON.stringify(guessThisTime));
        for(let i = 0; i < 1000; i++){
            let iterations = 10;
            for(let focuser = 0; focuser < iterations; focuser++){
                let range = 10 * (focuser / iterations);
                let halfRange = range/2;
                clearCanvas();
                refineThisTime = JSON.parse(JSON.stringify(guessThisTime));
                if(Math.random() < 0.3){ refineThisTime.tl.x = refineThisTime.tl.x + (Math.random() * range) - halfRange; }
                if(Math.random() < 0.3){ refineThisTime.tl.y = refineThisTime.tl.y + (Math.random() * range) - halfRange; }
                if(Math.random() < 0.3){ refineThisTime.tr.x = refineThisTime.tr.x + (Math.random() * range) - halfRange; }
                if(Math.random() < 0.3){ refineThisTime.tr.y = refineThisTime.tr.y + (Math.random() * range) - halfRange; }
                if(Math.random() < 0.3){ refineThisTime.br.x = refineThisTime.br.x + (Math.random() * range) - halfRange; }
                refineThisTime = computeLinesFitness(measurements, refineThisTime);
                if(1/refineThisTime.fitness > 1/guessThisTime.fitness){
                    console.log("Fitness: " + 1/refineThisTime.fitness);
                    guessThisTime = JSON.parse(JSON.stringify(refineThisTime));
        printResults(currentBest);
//    printResults(initialGuess);
(theres a few other mods to the code to make this work too)
one of the things to note is:
It’s important that we’re potentially randomising only some of the values - for resampling, we want to try small variations on the current as well as medium ones. 0.3 is arbitrary but I think ok - it’s something that could do with testing with a proper data set.
When I find some time i’ll tidy it up into some commits other people can try. I suspect it might well work best with a round of weighted mean as an early way of getting ballpark measurements to save a bit of time, and emphasising a bit more robustness :thinking:
I love this approach, that seems like a very promising avenue of research.
I think that the real gold standard is if we run it 10x in a row on the same frame how close to the same locations do we get? The perfect system should give us the same numbers every time.
