…but Maslow can cut light gauge aluminum and other soft metals, where 0.1mm accuracy is not unusual.
I agree with you on the deflection and swell/warp of wood, which is why I plan to use Unistrut or steel channel for the frame. And your metal linkages should help also.
There are higher accuracy #25 chains with tight tolerances. And if #25 isn’t stiff wnough, we can go to bigger gauge chains.
Maybe we add one more LVDT-based encoder at the top between the motors and link it to the sled via thin wire for additional position feedback to help with the router hitting knots in the wood like you said.
Just some ideas. I’m sure the people on this forum have more.
Even with all the above, the price of a Maslow would still be significantly less than any comparable CNC router I’ve seen (for example see: https://www.kickstarter.com/projects/2130625347/goliath-cnc-an-autonomous-robotic-machine-tool-for/description )
I think +/-0.1mm is achievable (ok, let me be more accurate: I FEEL that +/-0.1mm is achievable). The encoder resolution is there. And there are great minds on this forum ironing out the inaccuracies one by one.
Even though this started as a hobby CNC, I think by the time we’re done it’s going to be “professional grade”
We’re going to get there…
