Calibration moving one motor wrong direction in Ground Control V1.08
I am having the same issue with the right motor. Is there a work around/patch for this. Thank you!
Going through the test described above, the left chain pays out correctly, but the right motor turns the same direction of the left one, where it should be the opposite, so the right chain just falls off.
Yes, the right sprocket turns the wrong way. Also, I hooked up the sled and everything is backwards, i.e. Up is Down, Left is Right, etc.
Are you set for top feed or bottom feed?
Top feed.
I think this is normal. The software is expecting the chain to remain on the left sprocket and so it should be retracting the chain at that point instead of extending it
I figured it out … I did two things wrong. I selected that it was quad instead of tri, and I selected top instead of bottom. Totally my fault and it works beautifuly! Thank you for y’all’s responses!
-Scott.
That makes you an official member! We’ve all done some combination of those :grin:
Why thank you! I’m excited to see what I can make with her … but first … a proper sled!
