UPD: We are cutting!
I removed the wing nuts from the bolts where belt anchors go, so they can pivot. That alone improved a lot of things. Calibration ran without hiccups.
Sled still lift ever so slightly in places, but one I get vacuum hooked up it should be enough weight to keep it down.
There is some stutter here and there, so I’m going to try adding some wax to the bottom of the sled.
Accuracy is pretty good, however I had a 5mm deviation on one of the corners of the bottom shelf piece. Not sure what caused that. I think that was near the corner of plywood sheet. So maybe I need to calibrate using even larger perimeter (I did 2000x1000).
There was a hiccup with the travel passes, where bit was suppose to be above the surface, but didn’t. That might be those settings in fusion that I didn’t get right.
Overall, not too terrible for a first cut.
