Not sure if this should be here or somewhere else but… one of the things I think would be neat would be a router bit with roundover edges so that – if it’s placed at the right depth and it’s the right “thickness”, you could roundover both sides while your work is held in with tabs (it would be cutting the tabs…)
I suppose it should also have a 1/2"x 1/4" circle for plunge cutting so I could (with a lot of wood waste?) use that single bit to go from ply to finished with a single bit…
That CAM path sounds very complicated though (easy enough in concept make your roughing cuts 1/2"+2mm from the path, cut through everything and leave tabs at these spots, do a finishing pass at full depth, stepping into 1/4" from the path; cut the larger tab at the top of the work last – so, sounds like 2 toolpaths on a single shape in MakerCAM)…
Then again… is the amount of dust gonna be worth it versus taking the cut part to my router table to finish it?
Not to correct the one and only here, but perhaps the point-cutting style of roundover would help w/ the plunge action / z axis? I have had trouble with bits that don’t have flutes on the end aka bottom-cleaning bits when using a plunge router.
