I’m relatively new EstlCAM however, I recall in the tutorial videos on YouTube there are various ways of modifying and manually performing selections. My advice would be to review those vidoes. My sense is that it is possible based on what I took away from those vidoes.
I have run into similar problem with Fusion360 where it would not select contours like this because of the rounded corners. The easiest way I dealt with it was to just create additional paths or objects specifically for the first pass (red).
If you choose the manual contour “program” and you go with the pointer over the contour the contour gets green… then all you have to do is just do a right click and the green contour-suggestion is chosen!
Works perfect!
Another question:
Is there any chance to change the “repositioning” to the saftey height (for me 5mm) between going one step deeper? Without doing it manually in the gcode?
For example:
When i do cutout like this
Its 10mm deep, and the first layer is cut with 3mm.
After the first layer the program sends the z-axis back to 5 to go then to -6mm…this costs time and is not really necessary. It would be better to just go one mm up and then down again.
Like
Start +5mm
First Layer -3mm
back to -2mm
then second layer -6mm
