Job Bounds issues
2 small requests:
  1. Units: when changing the units from mm to inches, all of the UI should be updated. Right now, only the X,Y, and Z coordinates switch to inches, but the Jon Bounds remain in mm
  1. Can the Job bounds also show what the maximum and minimum X and Y positions would be? the origin is not necessarily at the center
Those are excellent improvements!
Can I push you to try the open source AI system by making an issue describing what you want here: Issues · MaslowCNC/Maslow_4 · GitHub
Here’s a quick video on how it works:
added both of these as well as the automatic anchor finding to Issues · MaslowCNC/Maslow_4 · GitHub
I’ll let you review and approve the AI-generated code
