Is there setting to calibrate the machine to multiple frames? I would like to be able to have a frame at my house and a frame at the haunted attraction i work at without having to transport. This would also be helpful to be able to bring onto various jobsites construct a frame or bolt to the floor, do what needs to be done than move onto the next.. @bar
Once you have calibrated the machine you have a .yaml file that contains all of the necessary information for the machine to work with a particular frame (relative position of all four anchors), and the stock you are working with (z height of all four arms)
Download it on your computer and name it so that you know for which frame it is.
If you change your frame, you’ll need to calibrate (or calculate the coordinates using manual measurements) again and download the .yaml for this new frame.
Then you will have a collection of .yaml file
just upload the one corresponding to the frame you are working with to the machine (you’ll have to rename it maslow.yaml before uploading it)
there is no automatic feature that I know of, it has to be done manually and you’ll need to reboot the machine once it’s done.
This is all correct.
