Maslow after repair and loosening the coils reliably retracts the belts, I tried to increase the retraction force to 900, the calibration was 600. Maslow cut to the brim nicely and accurately.
I don’t understand what happened when it only stood for a week
hello. look at my last topic. where I cut everything to my satisfaction. it just worked and I cut. now after a week I will pull it out. I will set up a 28mm work. plate. I do not use offsets. my anchors are at the height of the coils. and I am experiencing a misalignment and inaccurate plunge of the cutter
I think that this is probably the smartest first thing to look at. Basically just lower the z-axis all the way down and press the “Set Z-Stop” button to let the machine know where it is. It’s possible that something led to that home position being off.
To reset the Z stop without pulling out the router bit, lift the Maslow on a couple of blocks of timber so the Z axis can go right down. You can Release Tension and disconnect a belt so you can lift it up without strain while adjusting Z stop
It would have been set when you did Find Anchors, but sometimes it gets lost.
Under the setup menu and yes, it is a different button. Just below Release Tension
Lately I also have a problem with losing connection while cutting. After that there is nothing I can do with the machine except turn it off and pull the belts out and in again and all over again… But that is another topic.
