Thoughts on designing a new controller
@blurfl did you get the TLE chip working with an ESP32? I am running into issues with the serial connection setup
I haven’t looked at the TLE5206 or TLE9201 on the ESP32-Experiment code.
In the Maslow firmware I just used the dedicated DIR, PWM and DISable pins. I didn’t use the SPI, instead used SerialOutput wired as an error flag.
I’m interested in experimenting, though, and I’ve got one of the IFX9201 kit boards on hand if there are tests I can run :grin::+1:.
(Edit) I see you’re working on the TLC5947. It’s been a while, but I did get an ESP32 to control multiple motors using a TLC5947. I didn’t use the Adafruit library, instead used an array of 12-bit values (High/LOW/PWM) for the 24 pins and sent that when any one of the values changed. I’ve got a very messy sketch I could email to you…
I’ve been using the TLC5971 which is the baby brother of the 5947. I would love to take a look at how your sketch if you are willing to share. I’ve been playing with the adafruit library and another one with minimal luck. I think the much faster clock speed on the ESP32 might be messing with the execution of some of their code.
Edit:
I’ve got one of the new controller boards populated. I’ve found a couple mistakes so far, but nothing that can’t be fixed with a green wire or two and fixed in the next iteration. So far I’ve been able to read from all five encoders ports, up next is driving a motor from each port.
Do you have any more of these?
I ended up finding a couple issues with some of my IO pin choices with version one of this board so I am working on making a new one, I can absolutely send you one if you are interested.
The place I am currently stuck (although it has been a little while since it was my main focus) is on getting the ESP32 to talk to the LED driver chip over SPI
Which is the LED driver chip (U1 under the ESP32)? What is the current version of the firmware on the ESP 32?
Has there been any progress on a new board? I’m running low on my TLE5206 boards, I can order some new ones and use existing parts stock, but the TLE5206 chips have been discontinued. I’m guessing sometime in the next year they will be all gone.
Or we could switch to the original boards, but that’s a step backwards IMHO.
Or we could embrace the new Duo Boards, but there has been so very little feedback by real world users. Hard to spend $$$ thousands on new boards without feedback.
In designing a new board, I would look to a few key things
motor controller chips that can be switched by 3.3v or level converters
level converters for the encoder signals
option of voltage regulator to power arduino (3.3v or 5v)
place to plug in or optional eeprom (unless it’s cheap enough to just always
include one)
and then the obvious things we’ve talked about many times
thermal protection on the motor controller chips
as high a current capacity as we can reasonably afford :slight_smile:
I do not have the electronics background to design a board from scratch. What I’m asking is there anybody here that can take the existing TLE5260 board and put new motor controllers on it because the TLE5260 will be unavailable soon. As a supplier I can afford to pay someone to design it, I’d prefer to hire someone here than a stranger not familar with the product.
