I use my maslow infrequently. I hadn’t updated any software in about a year. I went through git and pulled updates on all the repositories, then tried to launch GC as I used to. Got the following error:
[INFO ] [Text ] Provider: sdl2 [ERROR ] [filechooser ] win32file module is missing [ERROR ] [filechooser ] we cant check if a file is hidden or not [CRITICAL] [App ] Unable to get a Window, abort.
Thought maybe I needed to update python/kivy or something like that. Went though these instructions:
now I get a different error:
[INFO ] [Logger ] Record log in C:\Users\Graham.kivy\logs\kivy_19-12-04_
17.txt
[INFO ] [Kivy ] v1.10.1
[INFO ] [Python ] v2.7.17 (v2.7.17:c2f86d86e6, Oct 19 2019, 21:01:17) [MS
C v.1500 64 bit (AMD64)]
- Traceback (most recent call last):*
- File “main.py”, line 12, in *
from kivy.app import App* - File “C:\Python27\lib\site-packages\kivy\app.py”, line 319, in *
from kivy.base import runTouchApp, stopTouchApp* - File “C:\Python27\lib\site-packages\kivy\base.py”, line 26, in *
from kivy.clock import Clock* - File “C:\Python27\lib\site-packages\kivy\clock.py”, line 362, in *
from kivy._clock import CyClockBase, ClockEvent, FreeClockEvent, \* - ImportError: DLL load failed: %1 is not a valid Win32 application.*
I just want to cut something! So I said forget trying to run from source and just run the compiled GC distribution. Downloaded GroundControl-Windows.Portable.v1.26
Trying to run that fails too! The window just blips, but if I’m fast with “print screen” I catch:
Any suggestions?
