UI/UX Brainstorming
It would seem there’s been a rollback of the double-tap or hold 4 seconds to set XY home (which was never very good on my iPad; it took an indeterminate number of touches to successfully double-tap, and every time I tried to hold, it selected the text on the button), and now (v0.88), I can’t set it at all from my iPad. Works from my computer, but sometimes the iPad is the least cumbersome option.
Any thoughts on if/when that might have a resolution?
Mahalo,
I did that originally so I could have a look again. A lot of the event handling has been cleaned up, but that’s just moving things from one place (the HTML) to another (in the JS) where it belongs
I’m pretty sure that specific functionality I removed, because it would never work on most touch devices. Holding for that long brings up context menus, selects text, etc.
Is there a way that we can make it work on touch devices? Maybe double touch?
Instead of relying on a number of taps/clicks on the same target, why not just open a confirmation dialog:
if ( window.confirm("Are you sure you want to zero the Z axis") ){
     zeroZAxis();
} else {
   // do nothing
Really basic proof of concept https://codepen.io/tryon/pen/XJWbRqx
I think that we had that initially, but it was annoying to get a popup. Someone pointed out that the REAL right solution is probably to have an undo option so we don’t have to stress so much about making it hard to click accidentally
That’s the code I put in there - specifically an actual double click handler.
In tablet.js there’s this block of event handler declarations:
    // Buttons - Fourth Row
    id("tablettab_set_z_home").addEventListener("mousedown", tabletSetZHomeMDown);
    id("tablettab_set_z_home").addEventListener("mouseup", tabletSetZHomeMUp);
    id("tablettab_move_to_xy_home").addEventListener("click", moveHome);
    id("tablettab_toggle_units").addEventListener("click", toggleUnits);
    id("tablettab_set_xy_home").addEventListener("mousedown", setHomeClickDown);
    id("tablettab_set_xy_home").addEventListener("mouseup", setHomeClickUp);
    id("tablettab_set_xy_home").addEventListener("dblclick", setXYHome);
The last three all relate to that one button. And you can see the dblclick event handler registered there.
In many OSes there are specific settings for double click/tap, for both the delay between the individual clicks/taps and for the spatial tolerance between the clicks/taps.
And they sometimes tweak these without asking between OS versions.
Aaaand they sometimes don’t have a place in the OS settings to access these values and change them
