Which of the kit suppliers did you get you driver board from? I think that they all have their own firmware versions at this point, but I believe that they all use github to distribute them.
I am using tle 5206 board
Got it, I think that should work with the default firmware.
Letâs try this firmware and see if it works any different: GitHub - MaslowCNC/Firmware: Maslow Firmware
The key to downloading it is that green button up on the right.
Ok, so I downloaded that firmware. Before I had 1.26 and this is 1.28 and when I run webcontrol I get window that my version may not work correctly. When I click test motor/encoder motors are spining but in webcontrol there is no results. Also when I make pid tuning test, motors are spining but I donât receive test results (after few attempts I received result) Is there webcontrol compatible with new firmware version?
I guess it doesnât really matter which version we use as long as you and I are using the same one. Letâs go back to the 1.26 version which was working mostly, but can you post a link to where you got it from? That way I can look at that version and try to figure out what is going on
