2 sided engraved penguin sign
Here’s my first major project on my Maslow. My sister runs a Kona Ice truck, so I decided to make her some signs to point customers in the direct of her truck. Since I can’t paint anything free handed, I engraved both sides of the sign so I could “color in the lines”… It took approx 2 hr. to engraved the first side & approx. 3 hr. to engraved & do the full depth cut on the 2nd. side. I learned a lot with this project. I had the base of my sign too close to the corners of the MDF sheet, so they weren’t very accurate & I had to cut the base down a little.
Youtube time-lapse video:
Oops too close the the corners…
Before sanding & cleanup
After sanding & cleanup
Painted
Side by side, before paint & after (sorry bad lighting)
Very nice job. We need to collaborate on some things. The whole reason I bought the cnc is to do this type of thing for my Christmas displays.
Looks amazing! Thanks for sharing!
Impressive! And that’s with the older bracket system. I love how you stepped down some surfaces - I never thought to do that. You have any special painting technique or just paint the pockets?
You set up the g-code file yourself off an image? That seems daunting and time consuming for such a detailed cut like this. Would you mind sharing a quick summary of your process for prepping your g-code?
PS: I think you might need a softer chair to sit and watch it cut - perhaps a nice lazy boy…
A really good start! I love that this project shows off the pocketing capability of the Maslow. I think a lot of people are thinking of the Maslow mostly as a device for making flat cutouts.
I’m interested in what, if anything, you did to ensure proper registration (alignment) of the images on the two sides, and any issues you encountered.
that is spectacular! Definitely a POTW candidate!
That is a really impressive build, and great documentation of the process! I love the side by side photo.
The project of the week bar has been set high this week :grin:
I answered most of these questions over here:
You can use a flame (cigarette lighter or similar) to burn off the MDF hairs for a smooth finish. Sanding just creates more hairs.
