I am learning how to design in abundance through the programming prompts but I was wondering if it would be possible to use the mouse or at least sliders as an input device for numbers. Ideally one could click on the input for a move command and then drag in the picture space below in order to input the number? If that didn’t work then I would find active sliders really helpful. Sometimes I design by number but often I do it by moving things until they are in the right place. I have no concept of how the internal programming for abundance works but it is fun to play with.
Hi @wouldchuck. Not sure if a sliding value implementation is in the picture right now but I added up and down arrows to all the number inputs which might be helpful in inching things closer to where you want them in a more intuitive way. Hope this helps
Thank you. @mo-at-maslow That looks great. I need to figure out another project for it. Cool program
