Alternative Routers - Non US Options
while you are working on this sort of thing, could you please make one for the
kobalt router?
@bar @dlang thinking out loud here…
If you made the mount into 2 pieces, you could have a top common plate for the PCB, and then interchange the clip on to the top of the router - you could even just use a locating peg or two (ie 6mm stud on the bottom of the plate) and corresponding holes in the router plate. Quick glob of superglue between the plates and nothing is going anywhere.
It would mean as we work through the router configs and new ones come out, wouldn’t need to alter the PCB plate, just produce an STL for the new router clip.
Thoughts …?
