So I recently installed 3/4" poolzilla floor anchors and used 6" long 1/2 galvanized carriage bolts to screw into the floor anchors to mount the new larger belt ends (thanks to others for designing for me!). Below are a few observations:
I was running .79 vertically with no issues, I then Switched to horizontal and changed my frame dimensions and calibration grid, but I got a red light flash and error immediately after the belts tightened on initial start of calibration… It did this 3 times and I have no clue why… so I deleted yaml,and index files and updated to .81, and then calibration ran smooth. I got .59 fitness initially, but then decided to mess around with the BRZ,BLZ, TRZ and TLZ values.
After measuring the 4 arm heights from the concrete floor, and then measuring the belt end height from the concrete floor I inputted the values and re calibrated again. Note: 2 of the higher belt arms on the M4 resulted in negative values because the belt end is ‘lower’ than the arm. I’ve never seen negative values in peoples setups, but most people probably have belt ends lower than the arms I would think. Makes sense to me. I ended up with .68 fitness after tweaking the measurements.
I did a final tweak of the Z anchor values and re ran calibration to see if I could get a higher fitness again, but it never calculated fitness during or after calibration… which was odd. I ran a 5x5 Grid and it just went to 25 waypoints and said it measured them, and then the calibration was complete… but no fitness calculations… I thought that was odd. @bar I did this 3 times in a row, but no new fitness values.
negative Z offsets would mean the anchor end of the belts is higher than the
spool end (and this should be measured when the maslow is all the way down
against the steppers)
I think the point is the numbers are the height of the arms above the anchor points. I think this is really what they are, right? Just confusing terminology
terminology
I still haven’t had a chance to do the test on the anchor point height.
In my set up, where the anchor are mounted to the wall the flex is the same at all heights, so that problem wouldn’t occur.
