Anchor Point Location Simulation
A while back I made a little tool that shows whats happening as the machine is trying to locate the anchor points. When someone posts a log file usually one of the first things that I’ll do is throw it in there to see if there is one point that’s obviously off.
It’s been public for a while but you had to edit the code to put in the data so I made a web hosted version that you can just copy and paste the data into.
This is mostly a note to myself so that I can find it again, but I figured I would share. You can check it out here:
