Is the firmware working with android devices now? If so I didn’t find it in the documentation.
Thank you in advance for your help
Sorry, there haven’t been any advances on that front. Opportunity for a contribution, though, if you’re knowledgeable on that platform
It’s not what you asked for, but i just fond this
So you can use android to upload the firmware.
This can actually be very handy
we are getting closer to the point where you can just use a g-code sender to run
the maslow.
you could do it today if you do your calibration with GC and then look in the
logs to see what’s sent on startup after that and make that part of what you
send from the gcode sender at startup
Firmware is the operating software available on an Android device, and it is available in different versions designed by different manufacturers. Basically it’s the device-specific part of the software. … PDA: Android operating system and your customizations
No, the firmware only runs on an arduino, no android device.
