Thank You!
I havent had a chance to circle back and look at this part f his code yet but this explanation makes sense.
I noticed that the ‘hole’ function n Fusion creates this problem. Pretty crazy.
I suppose if you were machining a really hard material this might be appropriate, but not for my material selection, plastic.
Says a lot about Fusion.
I changed to ‘Bore’ in my design and the hundreds of spiral cuts have gone away.
Thanks for catching this.
Now if I could just solve my Z-axis problem I might actually be able to cut something
| jonatpridesleap
July 2 |
Thank You!
Was this what you referring to when you said your Z-axis cycles several times before each cut?
