I am trying to get my maslow calibrated, but I won’t even get past waypoint 0.
I tried too many times already and even created a drawing to visualize the offsets in relation to the frame, but I dont get anywhere. Maybe one of you has an idea where the problem could be?
I am running my maslow4 with v0.84. My Frame is 3000 mm by 2520 mm with the anchor points inset by 75mm from each border, so the dimensions are 2975 by 2370.
I entered this in the options:
And this is the log that I get:
Serial Messages
Index.html Version: 0.84
[MSG:INFO: FluidNC v0.83 (Maslow-Main-39543985-dirty)]
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 3]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Connecting to STA SSID:Flow42_MK2]
[MSG:INFO: Connecting.]
[MSG:INFO: Connectin[MSG:INFO: FluidNC v0.83 (Maslow-Main-39543985-dirty)]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Connecting…]
[MSG:INFO: Connected - IP is 192.168.2.16]
[MSG:INFO: WiFi on]
[MSG:INFO: SSDP Started]
[MSG:INFO: Caution: Unlocked]
[MSG:INFO: Set to comply]
[MSG:INFO: Bottom Right pulled tight with offset -1661.259]
[MSG:INFO: Bottom Left pulled tight with offset -1627.515]
[MSG:INFO: Top Right pulled tight with offset -1763.048]
[MSG:INFO: Top Left pulled tight with offset -1751.002]
[MSG:INFO: Center point deviation: TL: 0.125 TR: 0.154 BL: -106.214 BR: -92.808]
[MSG:ERR: Center point deviation over 100.000mmm, your coordinate system is not accurate, adjust your frame dimensions and restart.]
