in the hardware upgrade thread I made an effort to design an arm that would not need an idler gear, which looked really good until Bar pointed out that it could not be stacked as the motor overlapped the spool (oops)
So I went digging to find other options
@bar, what is the spec for the motors (speed/torque), and what is the spec for the motor drivers (max current)?
I’ve found a couple interesting options (for apples to apples comparisons, the motor shaft is in the same place as the current motors, but that can be adjusted
The current spool has an outer diameter of 125mm and a bearing dia of 82.5mm and doesn’t quite hold 14.5ft of belt (my calcs show it should be 126 and 82.8 with the belt turned in and belt teeth on the spool)
There are 37mm motors with the gear shaft offset 7mm from the center, this would allow a 18 tooth gear to extend past the side of the motor. This could mate up with a 97 tooth spool, which would be ~148mm on the outside, and 112mm opening at the bearing surface with room for 4500mm of belt
an example of motors in this class are:
3a stall current 37mm
https://www.aliexpress.us/item/3256805242378821.html
3a stall current 37.5mm
https://www.aliexpress.us/item/3256805252915678.html
There is also a line of high torque 32mm motors with centered drives, they would allow for a 24t gear at the motor and a 91 tooth spool with an OD of 139mm and a bearing surface of just under 100mm with 4500mm of belt
an example of this motor is:
4.5a stall current
https://www.aliexpress.us/item/3256807592368250.html
and finally, with the current 37mm motors, we would have to use a 27 tooth gear (43.5mm diameter, which would make the angles worse) with a 88 tooth spool, OD 135mm bearing diameter 95mm
