Configuration setting gone?
Has anyone else noticed that the “Work Thickness” setting suddenly resets to 0? I used the “Find Anchor Locations” feature with a specific setting (-20). Everything was working fine, but after a restart a day later, the setting was gone. The Wi-Fi SSID, Wi-Fi password, extension distance, and retraction force, however, always remain saved.
(FW 1.20)
That is interesting, I haven’t seen that, but I do know that when that panel first opens it can take a second for the right vales to be displayed…they should all update at the same time so that doesn’t explain what you are seeing.
Does it happen every time you refresh the page or is it just every now and then?
