Maslow 4 - z-probe settings set in the settings menu, but not changed in Probe panel
Edited to correct terminology:
Aloha,
I am not currently able to set up my machine for operation—space is the perennial issue—but I do plan to set up the z-probe per the thread Instructions - How To Make And Set Up A Z-Probe On The M4, and so among the first settings I change after a full firmware/index.html.gz/maslow.yaml upgrade is to turn on the probe panel and set the plate thickness to 0 (zero) in the drop-down Settings menu per the instructions linked above.
For the last several upgrades, I have noticed that even after setting the plate thickness to 0 in the settings menu, when I navigate to the probe panel after, the plate thickness is set to 0.5mm. It’s like the setting change doesn’t propagate to the probe panel.
Just FYI; not really a big deal at the moment.
BTW, @Andith, do you know if/how the setup process might have changed with the transition to 1.x firmware/index.html.gz/maslow.yaml?
Mahalo,
z-offset to 0 in the settings menu, when I navigate to the probe panel after,
the z-offset is set to 0.5mm. It’s like the setting change doesn’t propagate
to the probe panel.
the zoffset values for each anchor are not related to the z probe, they are the
difference between where the belt is at the anchor and at the frame (in the z
direction, with the router all the way down)
Edit:
My apologies; I don’t think I clearly communicated what I’m seeing.
I can set the plate thickness to 0 (zero) in the Preferences menu, but when I go to the probe panel, the value for plate thickness does not align with what I entered.
@md8n could this be related to the settings not persisting issue that we were seeing?
@bar, I suppose it could be, but it’s distinct; in the preferences menu, at least, the settings do persist now.
Not sure if this is related, but after upgrading to FW 1.05, I started experiencing a lot of persistence issues—values wouldn’t stick in the software, and the new X/Y scaling factors kept disappearing from my YAML file. I tried reuploading FW 1.05, but the update kept failing due to “not enough space.” Eventually, I flashed the firmware over USB, and everything started working again. I suspect some kind of memory corruption, maybe caused by a weak Wi-Fi signal during the update. Just a guess, though…
@bar the cause of the actual non-persistence issue has been fixed.
However, that code has other problems, like some of those values were never persisted anyway from certain screens, or only in certain specific circumstances.
This thing was an utter omnishambles - I figured out I had an introduced a bug … didn’t matter .. there were plenty others all interwoven in this bit of nascent nastiness.
If you wanna try it out for yourselves, here it is:
index.html.gz - v1.05.01 (117.4 KB)
Unfortunately, I’ve been really busy with other things and haven’t been able to make a cut in a while. I really need to update and test the probe instructions following firmware 1.0. I’m going out of town for a week, but can probably make some time to play with and update things after I get back.
I’ll be ready when you do…my M4 is updated, but I don’t have access to a frame at the moment (space issues and no need for current theatre projects), but I want to have it all set including z-probe when the next project crops up.
